- Joined
- Jul 12, 2005
- Threads
- 56
- Messages
- 371
Finally got the PIG running
. Put about 100 miles on her last weekend and went through about 10 gallons -- plugs are burning good now. Went through a period of "unmotivated behavior." Kept breaking bolts.
Changes:
Non-USA Asian Carb
Mated Used exhaust Manifold (pre-75) to Used Intake Manifold (72)
New intake exhaust manifold gasket
Machined manifold unit
Installed Step Down head bolts for manifold
Exhaust manifold a little warped but so far no leaks
New radiator hoses - have leak in the thermostat casing to fix with new gaskets-I'm sure the bolts will break-they all seem to break off on me no matter how careful I am or how long I soak with penetrating oil (that is what slows me down)
Thanks to Pighead for sending me "stuff."
I've got a cable linkage on it now but will convert to rods in future - need to sort out bracket for this carb. Could not make the "rally" this summer due to coaching baseball (March-August). Will install the air cleaner hopefully this weekend - Still need to get you some beers.
See pics -- also got my front signals fixed - installed new posts.
. Put about 100 miles on her last weekend and went through about 10 gallons -- plugs are burning good now. Went through a period of "unmotivated behavior." Kept breaking bolts.Changes:
Non-USA Asian Carb
I've got a cable linkage on it now but will convert to rods in future - need to sort out bracket for this carb. Could not make the "rally" this summer due to coaching baseball (March-August). Will install the air cleaner hopefully this weekend - Still need to get you some beers.See pics -- also got my front signals fixed - installed new posts.
