automatic download of service manuals FSM
That makes sense to me Lochsa and that's a good reason for getting all the URLs posted for a given year and model (LC, LX) so we can accumulate a complete list that others can use to build URL.TXT for their specific vehicle
Thanks!
-B-
Gotcha, ok that makes sense... so you did it manually. You sir have more patience than I!
Over break I hope to buy a 1 month TIS subscription and write an app (either c++, php, or perl, depending on how quickly the TIS server responds) to spider through all of the categories and sub pages to accumulate a comprehensive list of literally every PDF available. I intend to break down the PDF listings by major category (IE: repman-suspension.txt etc) however the first step is obviously getting a full list.
Thanks for the updates.
Get to work young man!
Make us all proud!
It was definitely some manual labor, but I managed to finish the whole thing in probably less than an hour, which still beats the heck out of downloading them one by one.
If you are able to get your project completed, however, you'll be my hero! If there's anything I can do to help, let me know.
Great news!
I got some work done on the system to spider the pages and I have local copies of the pages from which you select the PDF to view broken down by Major Category (folder) and subcategory (filename) for the repair manual.
I'm going to try and get a complete '96 LX450 Repair Manual PDF list done by tonight, and by the end of exams I should be able to complete lists for any model+document you ask for.
I'll be glad to take suggestions for how the wget lists should be organized.... I was thinking it would be wise to beak the lists down by categtory_subcategory.txt so that I can also have the script output a batch file which will place the PDFs into organized folders automatically, but this will break the internal links in the PDFs from one to another (for example the EGR PDFs link to other sections of the RM, these PDF "hyperlinks" wouldn't work)
If people care more about correctly working interlinked PDFs, a complete list where wget mimics the server's directory structure will work, and that is easy to create.
-----Nate
Finished run for: 1996 LEXUS LX450
Document: RM (C41)
total pdf links: 879
total master sections: 23
total subsections: 303
:bounce: :bounce: :grinpimp:
Who da man?
Alright Guys, ready for beta 1:bounce:
I need beta testers! This should be a complete, organized copy of the 1996 LX450 Repair Manual. Let me know if this setup works for you... if you like the directory structure, if it is too complicated, if it doesn't work at all, etc.
EDIT: New Instructions to Try
Here are the steps (some stolen from the OP :cheers: )
1) Download the downloader package located here: http://www.nate-online.com/tis/1996LexusLX450RM.zip
2) Unzip the package in a subfolder of the location where you want all of your PDFs. For example, if you want the repair manual in C:\Lexus\Repair\ you need to unzip the folder in the zipfile to that directory. This would mean that all those text files (etc) would be in C:\Lexus\Repair\1996 Lexus LX450 Repair Manual\Downloader\ after you unzip. It is important to note the zip file has a directory structure it will unpack to keep your PDFs from spilling out into some directory and creating clutter.
3) Login to TIS ( http://techinfo.toyota.com ) and download any (one, random) pdf from service manual.
4) Look at the list of current cookies at your browser and find one from toyota.com named SMSESSION (In firefox goto Tools->Options->Privacy->Show Cookies)
5) Locate the file cookies.txt in the folder where you unzipped everything and copy the part of the cookie that is very long and cryptic over the indicated text (the SMSESSION value will be long and look something like this F0M6xHW55..........)
6) Double click on begin_download.bat and follow the prompt. If you've done it correctly you'll get 873 PDFs totaling 20.2MB neatly organized.
Good luck and report back on how everything goes so I know what to change.
Below is a picture of how everything was automatically placed on my computer after running the batch file.
Nate,
From 50,000 feet it looks great! My vote would be for meaningful directory and filenames and it looks like that is the direction you took. As you pointed out, we will lose the internal hot-links but that seems like a minor issue.
I'll download your process and give it a try soon... hopefully tonight but probably this weekend.
Nice work!
-B-
... and by the end of exams I should be able to complete lists for any model+document you ask for.
Nate,
Will this be a dynamic process or something that you will do while you have time and then share your completed lists?
The reason that I ask is that many of us have other Toyotas in the stable. Some have 2 or 3 Land Cruisers but most of us have a Tacoma, Tundra, Camry, 4Runner, etc. If your process is dynamic then that would be outstanding. If not, then please describe the process you are using for creating the completed lists. It appears to be the same thing that CBS did using a 'grep-type' Editor.
Thanks again for sharing your work.
-B-
Nate,
-B-
Beowulf,
I run a php script I wrote called getpdflist.php
For right now I used the source of the javascript from the navigation page to plug in the return of the functions getSearchAll(), getCollsModelYear(), getYEARMODEL(), and getDivision(). This allows me to pull a list of all the sections and subsections in a specific document for a specific vehicle. In other words, each run of a vehicle is unique, but once I plug in which document and what vehicle, I just get a folder outputted which I right click and zip up, and I'm done.
I definitely think I could automate the entire process to get a list of every manual for every vehicle, however I'm not sure how happy toyota would be about all that traffic... it would be like viewing every possible page in the TIS system. :doh:
I agree.
It would be better to build individual lists.
-B-
Alright you 1997 LX450 owners, now its your turn, get it while it's hot. This is the complete Repair Manual, broken down into logical directories (as toyota has it laid out on the site). Same instructions as above, slightly cleaner "downloader" structure in this zip file.... let me know what you think and if you have any problems!
http://www.nate-online.com/tis/1997LexusLX450RM.zip
Also, for a limited time I'm taking requests for runs, so if you've got a document you really want to download for you model and you have not done so yet, let me know and I'll try spidering a structured download.
Actually, I'm on fire, here's one more for tonight... this is the 1995 Toyota Landcruiser Repair Manual, once again, same directions, feedback appreciated, yadda yadda yadda.
http://www.nate-online.com/tis/1995ToyotaLandcruiserRM.zip
Also: this goes for everyone. If you are using a TIS subscription and downloading these complete, organized manuals, please ONLY DOWNLOAD WHAT YOU WILL USE! Don't just download everything for the sake of it... it's a waste of toyota's bandwidth and we don't want to raise eyebrows or abuse the system. Thanks
NG,
My humble request would be for the '97 LC FSM. :bounce:
Thanks!
Whoa! That was quick! I will certainly let you know how it goes.. I will do this tomorrow.
Thanks again!
By special request, this is the Repair Manual for the 1994 Toyota Landcruiser :D
Same old same old, feedback, nags, "this sucks", "this is great", etc would be helpful!
Here is an updated list of all collections created so far. These are fully automated downloader packages, all you do is buy a TIS subscription, log in, get your cookie data, past it in cookies.txt and then run begin_download.bat and everything happens for you. The folder structure mimics the category->subcategory structure on the TIS website for logical location of the PDFs, however they keep their original file names.
2007:
Lexus LX470 New Car Features
Lexus LX470 Repair Manual
Lexus LX470 Wiring Diagrams
Toyota FJ Cruiser Repair Manual
Toyota Landcruiser New Car Features
Toyota Landcruiser Wiring Diagrams
Toyota RAV4 Repair Manual
2006:
Lexus LS430 New Car Features
Lexus LS430 Repair Manual
Lexus LS430 Wiring Diagrams
Toyota Tacoma New Car Features
Toyota Tacoma Repair Manual
Toyota Tacoma Wiring Diagrams
2005:
Lexus LX470 ATM Unit Repair
Toyota 4Runner Repair Manual
Toyota Landcruiser ATM Unit Repair
2004:
Toyota Tacoma ATM Unit Repair
2003:
2002:
2001:
Lexus GS300 ATM Unit Repair
Lexus GS300 New Car Features
Lexus GS300 Repair Manual
Lexus GS300 Wiring Diagrams
Toyota Camry ATM Unit Repair
Toyota Camry New Car Features
Toyota Camry Owner's Manual
Toyota Camry Repair Manual
Toyota Camry Wiring Diagrams
Toyota 4Runner ATM Unit Repair
Toyota 4Runner New Car Features
Toyota 4Runner Owner's Manual
Toyota 4Runner Wiring Diagrams
Toyota Tundra ATM Unit Repair
Toyota Tundra New Car Features
Toyota Tundra Owner's Manual
Toyota Tundra Repair Manual
Toyota Tundra Wiring Diagrams
2000:
Toyota Sienna Repair Manual
1999:
1998:
Toyota Landcruiser Technician's Reference
1997:
Lexus LX450 ATM Unit Repair
Lexus LX450 New Car Features
Lexus LX450 Wiring Diagrams
1996:
1995:
Toyota T100 Repair Manual
1994:
Lexus LS400 ATM Unit Repair
Lexus LS400 New Car Features
Lexus LS400 Repair Manual
Lexus LS400 Wiring Diagrams
Toyota Supra ATM Unit Repair
Toyota Supra New Car Features
Toyota Supra Repair Manual
Toyota Supra Wiring Diagrams
1993:
1992:
1991:
1990:
I can procure EWDs, etc, however I am prioritizing FSMs because they seem most in demand. Also, you are welcome to ask for something, I'm trying to generate lists based on how common they seem (which models are most common) but this is not limited to Landcruisers, the FJC community and 100 series community (and any other model for that matter) are technically fair game. I'm spacing the generation of lists apart by a few hours to reduce the load on the TIS system and avoid doing anything that I suspect would annoy toyota, so be patient if you ask for something... I'll definitely get to it as soon as I feel it is prudent to do so.
Nice work. Downloaded the manual for the 2000 LC. However, I just realized I have a 2001 (it is very late). Can you write a downloader for the 2001 Land Cruiser. If you can do on Friday, I can make an online video/tutorial showing how to do.
Thanks
