) due to space limitations. I also had to plan for hydro-assist cylinder space. Plenty of options, just depends on which you can get to fit the *best Unfortunately, I would need a suck down winch to solve this issue... it binds just sitting there![]()
One that has crossed my mind is doing lower links as wide as possible at the axle and at the frame mounted to the outside of the frame. The upper link would be be on the passenger side of the axle and "high" on the inner frame.
Now that I'm firmly entrenched on doing a three link, I'm going to look into the various types. So far, not ruling out anything. I've even considered a bronco style radius arm setup (glad I've got a set of new cast wedges)
