- Joined
- Sep 21, 2007
- Threads
- 233
- Messages
- 3,908
Hey guys, as I plan out my upgrades for my 100 series, I came across several rigs with external fuse blocks. I am pretty sure that I can add my external fuse block with some help, do you guys have writeups on adding external fuse blocks? Or maybe a link to a VERY detailed writeup, since this is the first wiring job I will do on my 100 series landcruiser. I have seen several systems with a circuit breaker located in the hood but I want to know if it is possible to put the circuit breaker in the actual truck near my oem switches so it can be shut off without having to open the hood. Im hoping my setup will allow for all the added accessories that are connected to the external fuse block will shut off when the vehicle is turned off. Thanks in advance guys!
