My 1HZ has always ran a little warm going up our steep Kootenay hills since I got it 1 1/2 years ago. Now that I am getting a trailer I decided I better check some things out.
Pulled apart my clutch fan yesterday and tested it using the excellent step by step thread:
https://forum.ih8mud.com/showthread.php?t=102633&
I was surprised to find that, though the unit looked in great shape, the clutch fan didn't start to "open" until the temp reached 180F. As per the above thread, that temp seems way high.
Is there a standard temp where those fans should kick in? According to the above thread the ideal is 95F. That's way way lower than mine was working at.
You can adjust the clutch fans (again check out the above thread) but the best I could get my fan down to was 140F. So I adjusted the fan and stuck in an extra tube of silicone lube and put it back on the truck.
Big change. Now the temp needle does not move (at about 1/4) even going up a fairly steep hill outside of town (Nelson).
I'll try it with a loaded trailer in a week or two, but it looks like the fan just wasn't working to spec any more. There may be natural deterioration in the outside temp spring due to age, no matter what the mileage (145k for my truck).
Big thanks to Rick and others for the great work on fan clutches in previous posts.
John
