Hey all. I've searched this issue but didn't find any conclusions. I get a noticable whine when accelerating between 55 and 60 mph, but at no other time. If i feather the throttle at that speed, right between coasting and accelerating, I can get a small virbration. It sounds like it is coming from the front end, but hard to tell (my hearing is not very good). It doesn't do it at all when the truck is loaded and the back end sits a little lower, which makes me think it might be related to the rear drive shaft.
I don't recall it doing this before i lifted it, but i lifted it pretty quickly after i got it and wasn't quite in tune with the truck before throwing mods on. It's been this way for the last 8k miles with no change. It's a '94 with 203k miles. OME heavy lift, 315s and 4.88 gears. All these mods were done at the same time and the front axle was rebuilt at that time too, all by a reputable LC mechanic (Mudrak). I'm guessing they are the original U-joints.
My questions are:
What do you guys think would cause this whine?
Has anyone successfully diagnosed and/or solved this problem?
Any harm in letting it go? It's slightly annoying, but livable and as long as you are not going that speed or are loaded down, you wouldn't think anything was wrong. I only get that slight vibration if i try. Naturally i don't want to cause damage if avoidable.
I'll start dropping driveshafts and throwing parts at it, but i wanted to get the opinion of the board first. Thanks for your input
My questions are:
