I need HELP. I was installing MAF 30mm spacers on the front. I took the driver side wheel off, lowered the axle on to a jack stand to compress the coil, put a strut compressor on both sides of the coil just to keep it compressed, raised the vehicle until the axle just barely lifted off the jacke, slid the OEM coil out with no problem. I got the MAF spacer to seat with a silicone spray, a hammer & a piece of wood. Before I could get the coil reinstalled the compressor slipped to one side. After several tries I could not get the coils compressed enough. No matter what i tried I need about 2" more to clearance to slide over the bumperstop & the bottom spring locator. What is the easiest way to get that much droop? Please help. I've got to get this & the other side finished tomorrow.
