Starter Issues after Rebuild
I installed a new Toyota starter rebuild kit last summer during my PM head gasket replacement. The starter works great about 90% of the time. The other 10% of the time, it makes an awful grinding noise which dissappears after the second attempt. Other times the starter does nothing but after a minute or so, it works fine. Should I pull the starter to verify if the new components are installed correctly or do you think this is related to low juice to the starter? Maybe a combination of both?
Thanks. Doug
I think its strange that the starter worked fine prior to the PM rebuild and now is having intermediate issues. I am going to pull it and check out the components.
Pull the starter and check the plunger and contacts...My guess is you did not get the contacts perfectly "flush" and "square" and you will see an area on one of the contacts that looks like a spot weld...This doesn't explain the noise part (mine didn't make any grinding noises) but could explain the sporadic working issue, until it just stops working all together
I've done 3 rebuilds...So far I'm only 1 for 3 on doing it correctly :rolleyes: - Rebuild I did on my LX is working just fine 3+ years later. Subsequent to that I've failed twice rebuilding the starter in the 80 and what you see below is what the starter looked like after 6 months. I rebuilt the starter again (using new parts) with the same results about 9 months later. Gave up and had someone else rebuild it the 3rd time :idea:
Check the teeth on the starter for the "wierd noise", if it sounds like it's grinding and not turning the engine over, the starter and flex plate teeth are damaged and need replaced. I have seen this before on older Toyotas.
My "grinding" description was incorrect. It sounds more like the starter does not have enough emph to properly turn over the engine. I definitely need to find some time to check the plunger, contacts and teeth. Thanks for the picture and replies.
Doug
I have a 97 LX-450. This morning when i was starting the car the starter gear stayed engaged after the car started, even after I turned off the ignition and pulled of the key, I can still hear the starter cranking......what the heck could be wrong. Could it be that i have a stuck starter solenoid and need a new starter.
Your starter contacts are shot and need replacement. This is probably the exact reason the OP rebuilt his starter when it was not broken.
Starter Rebuild
If you are inclined to work on it yourself, CDAN sells starter rebuild kits. Don't recall exactly but wanna say it was around $20. You will need to provide the starter model # to get the correct parts.
The hardest part was getting the starter out. Otherwise can be easily done in about 30 minutes.
jt
wheel bearings
Check out the FAQ section. There is a lot of good info on maintenance and anything else Cruiser related.
Are you having bearing issues? Have you checked for loose bearings/play? To do this raise one end up and grab one raised wheel at 3-9 o'clock and pull alternatively with left and right hands. Repeat at 6-12 o'clock. If there is play the wheel will move from side-to-side. How many miles on your rig? What service has been done?
The front axle service is due every 60k. This is a good time to inspect the bearings and replace if necessary. I believe the service manual calls for bearing repack every 30k.
Cheers, jt
His photo illustrates what happens when the new contacts are not perpendicular to the plunger contact surface. The service manual specifies that a wooden block of specific dimensions be fabrictated and then pressed against the contacts with a specific force before the contacts are tightened.
The block is intended to prevent the contacts from rocking when the nuts are tightened. This is critical.
This is the exact method I used to install my contacts. They must have been a red hair off when I tightened the nuts. I'll try again this weekend.
Dan, just for S&G's, what does a new starter run nowadays?
Current published list price on the 2.0kw is $251.59 exchange, net $188.69 exchange. There is a $30.00 core value.
Now you tell me :confused: :hillbilly:
This was just your secret way of getting me to order more parts, wasn't it...:D
Seriously though, as Dan states that is what you are supposed to do and the FSM spells it out pretty clearly. My mistake was assuming that just because I could do this once without the proper tools (perfectly sized piece of wood and no press for the needed 221lbf of force) and without problems meant I could repeat my success :doh:
But, now all of you know what might happen if you don't follow the FSM and what it might look like inside your starter - I'm sure you're all thanking me right now :flipoff2:
