This thread is dedicated to VAF sensor illogic.
I decided today that I would look into cleaning the AFM (aka, MAF, VAF) sensor to see if this would help gain a little power.
**I will update this thread with proper terminology once I retrieve my FSM from the Cruiser, more than likely tomorrow. Anyone who wishes to add diagrams or pictures, please feel free to post.**
Well, I have never messed with this before, and just like anything else, I briefly skimmed the FSM to gain an understanding of what I was looking for; then I began to take everything apart from the air cleaner.
In so doing, I unscrewed the sensor plug (DO NOT EVER DO THIS) - and out came all of the various connectors from the housing's PC board when I gave it a tug. Now, I know that there are many knowledgeable here who would cringe at the thought of being so reckless, but I was not paying much attention, which is reminiscent of my whole day today. :whoops:
I attempted to simply put the plug receptacle back into place, plugging in the exposed leads, but the engine would not start. I unplugged the unit altogether, then it started; but it quickly died, so then I knew it had something to do with the plug.
To get to the point, I was stuck wondering what to do since I pretty much ruined a perfectly good running engine:
Option 1: Park it and check the classifieds for a replacement housing.
Option 2: I am not going any where, so may as well remove the sealant on the cover and attempt to figure it all out.
Being who I am, I went with option 2.
First, I removed the housing from the truck and brought it to the work bench.
I cut away the rubber sealant from the plastic housing, being careful (for the first time tonight) not to puncture the thin plastic cover. I used a screwdriver to remove the sealant so that the chances of cutting were reduced.
Next, I removed the plastic cover and took a look inside. There were three blade connectors on the plug receptacle that were in alignment with where the female end of the wires would eventually meet. I made note of this for reassembly.
I saw that I had pulled three other posts from the PC board during the initial removal: these needed to be soldered back into place.
I soldered the three posts back onto the PC board, then re-attached all of the connectors, replaced the plastic cover; then I used a silicon sealant to make it water-tight. I allowed this to dry, then assembled it back onto the air intake.
I plugged the sensor cable back in and turned the ignition key:
It started right up!
I am breathing a sigh of relief right now, but I will not know fully how this "tune up" worked out until I drive it to work tomorrow.
I will keep you all updated as testing progresses.
