Gauges location.
Asturias(Spain)-London(England)
www.sybaris-expediciones.com
I'm going to get a pair of VDO gauges for EGT and boost and I already have a transmission temperature gauge installed.
I'm looking for a place for them and, for now, I can think of these possibilities:
Generic DIN insert under the stereo. Would it be easy to route the wires and hoses this way?
I'm also concerned about the horizontal vision angle, not facing the driver.
Anothe option is one of these consoles, placed just in front of the tranfer lever.
In this case, the horizontal angle is not a concern, as they are driver-oriented (they have RHD and LHD models), but vertical angle is. It may be a very low location to read them properly.
Also, they offer these mounting brackets:
But I can't think on a way to be installed in an 80.
Any comments / ideas / pics?
PS: My truck is a RHD
Thanks a lot.
Thank you guys.
It's good to see I can use a pillar mount in the RHD, but I'm not a big fan of pillar mounts, plus I wouldn't like to sacrifice the handle. My truck is lifted almost 4" and is hard to get in!
What do you think about the other solutions?
I had my EGT on a pillar mount, but it kept on falling off every now and then, so I moved it down low when I added the boost.
I went with the Wedgee Dash Pod like Tapage, worked pretty good:meh:
I just had an stupid idea.
What about installing one of this LHD consoles:
In a RHD car but installing them upside down just like phrogg4ever pod?
Well .. the das DIN plate looks good .. but in my case it really don't fit ( I use one similar from glowshift ) so I just go with the ISSPRO pod route .. and I'm just happy .. coz the A pillars pod are for tunners ( IMOP ) ..
more info here ..
https://forum.ih8mud.com/80-series-tech/284595-marilu-upgrades-ver-2009-a.html
I agree.
Amazing 80 series you have there!. Have you replaced the auto transmission by a manual?. I wish I had done that when I broke my A442F, in my opinion manual transmissions are better.
By the way, it's the first one I see with the stock fridge without being a VX Limited. Have you purchased the fridge separately?
Another question Tapage, I've read you have used Both VDO and ISSPRO gauges. Do you think it's worth to expend extra $60 euros more that the ISSPRO boost and pyrometers cost compared with the VDO?
Thanks !
Yes I do .. big PITA ! the hole job .. but I'm frea** happy now .. coz now I'm " driving "
No .. it come factory in Marilu along with my aux tank and dual AC ..
yes .. the ISSPRO pyro have a better response compared to the VDO the instalation it's much more easy have better ilumination due to the separate control boxes in ISSPRO ..
You have a circuit box .. in the " gauge " itself only come the light ..
I mulled this over for awhile and decided on the solution in the attached pics. I liked the idea of hanging them from beneath the dash behind the shift levers but there appears to be a vent behind that lower panel. Also, mounting them behind the levers anywhere would require you to remove them if you need to remove the shifter console or center console.
I was thinking in something like .. but as I'm 6.2 with long legs .. I decide the other side was a better idea ( codriverside ) .. actually there is my tranny temp it's right now ..
aren't the gauges there a problem with your right leg . ?
They would drive me nuts there. The PO of my 81 had mounted some switches for something in the same place (well opposite hand rhd thing). My legs were always riding against them, it was uncomfortable, and would occasionally flick one on. I still don't know what they did, but a little l.e.d. light on top of the switch would go on.
I'm 5'11". I was concerned with my right leg during the install. When I got it done and took it for a test drive , I got home and realized I had totally forgot the possible leg comfort issue. It has been a completely non-issue for me. Half of the time my leg is straight up and down and not leaning towards the shifter console at all. When my leg does lean over it rests on the gauges instead of the shifter console; I don't think it's any more uncomfortable than when my leg rested on the console itself.
I don't have a boost gauge but I stuck my digital egt meter in (well, behind) the opening for the hazard switch, which I relocated in the bottom of the dash in one of the empty spots. I'll try to find a pic but needless to say it's brilliantly clean and practical :D
it looks nice .. where do you found it . .?
Our man in the land of Mr. T (Mot) found that. It's a little pricey at $185 I think he said, so I'm still browsing.
I've been looking around some aussie forums, but its quite odd, doesn't seem to be a lot of options for 80 series. Lot's for 70's and 100's tho.
