- Joined
- Dec 27, 2004
- Threads
- 4
- Messages
- 31
I bought a low-end jack that only goes to 13" which isn't high enough to lift the front off the ground if you use the recommended lifting points (each end of the front axle). I figured out by using the OEM bottle jack that I need about 15".
So my question is, could I place the jack in the center of the axle, where it is closer to the ground? The user manual and Chilton each only mention the ends of the axles, so I assume those ARE the safest points, but are they the only points?
I have jack stands that I plan to use once I get it up high enough.
I know that the obvious answer is to get a better jack, but I don't want to sink too much money into a jack that I may not end up using but once or twice a year.
