Brake Bleeder
Columbus, OH
I got my Harbor Freight brake bleeder and got three of my calipers blead. The fluid came out black so I assume it was the original. The bleeder is stuck on the last wheel. I soaked it with PB blaster for an hour and still no luck. I will continue to use more PB every day for a week and see if that helps. I was tempted to use some heat but decided not to due to the various seals. Is there anything else I can do to get this lose? Thanks in advance for your suggestions
Bleader
Well you did better than my son when he bought one here in Ct ,took it home to Wy. and it was defective and there are no harbor freights in Wyoming, heh heh. We did it the old fashioned way when i visited him ,Dad pumped and held, Son Bled.
Is it stuck on the nipple???
If so can you just replace the nipple????:idea::idea:
impact or hand impact and a hammer...
Try tapping the bleeder screw with a hammer. The vibrations can help the PB work its way in.
It's *REALLY* easy to strip or damage that bleeder.
I would try some heat, and repeated soakings of PB. Breathed's suggestion of lightly tapping it is a good one too (make sure you tap the end, and use something soft like a brass hammer/drift).
You can also pull the caliper completely. Having it on a bench will be easier to get it off, and if there's no pressure from the brake fluid that'll help too.
Worst case scenario replace the caliper. When I needed to replace one, cdan recommended replacing both sides, which I did and do not regret. Alternatively you could pick up a used one and do a full R&R of both calipers. The idea is that you get the same performance out of both (one new and one old is not ideal as the new will likely grip better than the old).
One of my nipple is frozen as well and adding too much force will simply brake it off! I like the brass hammer idea though. Do not break that nipple off as the system will drain through that nipple. If the fluid isn't coming out, it only means that the tiny orifice on the inside is clogged and it's a matter of time before it frees itself under high pressure.
G'day,
First suggestion is pipe spanner.. If this seems like still rounding nipple, heat is your friend, have had a couple of 'stuck' bolts (and a nipple) on my truck and a friends oxy has been enough to 'loosen' the thread. Don't go overboard though, too much heat can cause more problems than original issue...
Ross.
G'day,
Ross.
There's plenty of room to use a deep socket on the brake nipples, so rounding them is not an issue on the 80 series. I like your heating idea though.
