if the 3b is beefed up a bit with a nice turbo, would it be powerful enough to move an 80 series? how difficult would the swap be? i don't remember this being covered before...
Don't know what the standard HP output would be for a 3B, but HZJ80s had 130 hp under the hood IIRC. So if you're not a fastlane freak, go for it.
The new 4.5i Duramax would be a nice swap when they come out for the 2009 model year. They make 520 ft/lbs of torque and supposedly get 28-30mpg in a full size GM truck! I'm sure they will be pricey.
PickupTruck.Com - Updated - GM Announces 4.5-liter Duramax V8 for Light Duty Pickups
2010 Suburban with 4.5i Duramax-
2010 Suburban Duramax 4.5 Liter
I don't know why toyota doesn't offer a diesel motor in the US market. It seems that if VW and diamler can find a market for diesel motors here, why can't toyota?
1HD-T uses the same block as the 1HZ, but has 165HP and 268 ft/lbs of torque in stock form. With an intercooler and tweaked fuel pump you can reach 210HP and over 400ft/lbs of torque.Good point...
3B = 90HP and 159ft/lbs
13BT (similar to a turbo charged 3B) = 120HP and 210ft/lbs
1HZ = 135HP and 187ft/lbs
