Throttle cable adjustment?
West of the Pecos
I just did this yesterday and I am amazed at how much better the truck feels! Anybody who hasn't done this needs to do it, right now! You will love the results.
QUESTION: What exactly does taking up the slack in the throttle cable do?
I tightened up the throttle cable to put the "bead" about 2mm or so from the red boot, and also took up about the same amount of slack in the accelerator cable. Which got me thinking... To me "throttle" = "accelerator".... Can someone explain the difference to me?
Truck runs GREAT and shifts a LOT better/smoother, so I'm not unhappy at all. Just trying to figure out what the heck I did, exactly.
It takes up the slack in the throttle cable...
:D
which means that the accelerator pedal no longer has a range of motion in which it does absolutely nothing to the throttle body.
The throttle cable and accelerator cable are two different critters.
I understand what tightening up the accelerator cable did, but what does tightening up the throttle cable do???
Umm not quite sure what you're referring to. There are three cables on the throttle body: throttle cable, cruiser control cable, transmission cable. Did you in fact adjust the transmission cable? This cable is used by the transmission for kick down and I'm sure some other things that the transmission calculates based on the throttle body.
I believe the cable with the ball is the transmission cable, so it does seem that is what you adjusted.
Here's what I did. 80-series Throttle Adjustment - Land Cruiser Tech from IH8MUD.com
BUT, it looks different on my 3FE. Up near the throttle body, there are TWO cables in a bracket with nuts to adjust tension on both sides of the bracket. One is the accelerator cable. Unless I've been reading things wrong, the other is the "throttle" cable that has a red rubber "boot" on the end of the threads on the throttle body side of the bracket, and the "bead" on the cable.
The picture that most closely matches what I see on my engine is the FJ62 pic in my Haynes manual.
I may have the nomenclature wrong, but the link above and my Haynes manual both call the cable with the red boot the "throttle cable". Whatever the heck I did, it made the truck run a LOT better! I'm just curious because "throttle" and "accelerator" mean the same thing in my mind, but there are two different cables.
I just want to understand how my adjustment of the red-booted cable did what it seems to have done.
The FAQ link says:
A and H are the throttle cable (connected to the transmission)
So you adjusted the "kick down" cable.
Okay, but what exactly does that do???
Keep in mind that I was that kid in school that was always asking the teacher "WHY?" -- never content to just memorize the formula and get the correct answer.
Well then, get out your FSM and look. A vague answer would be that it changes hydraulic pressures in the valve body, so for example, after adjustment, lower (higher?) pressures are obtained for a given throttle position, causing later upshifts/earlier downshifts.
Curtis
I know we call that the "kickdown" cable around here, but I'm pretty sure the FSM actually calls it the throttle cable. (As in, from the tranny to the throttle, I guess.)
That's probably right. Oh semantics.
Curtis
I guess I need to get one of those FSM's one of these days... :hillbilly:
My diesel 80 has a good 1/4 inch or about 6 mm of slack in the accel cable that is NLA from Toyota. I have a new after market Japanese made one but its nothing like the qual of the original.
Is it possible to overcome the slack or is fitting the replacement cable the only viable solution with a diesel? My 80 is 24 yrs old. 8-)
Ta, Craig.
