Back story:
I had a squeak associated with rotation in the front end. Traced it to the front pinion flange (as far as I knew) but had no change with spacing the dust flange away. Noticed the front driveshaft looked funny...had play (very little) in the u-joints and could be physically bowed in the middle (scary).
Took the shaft off today (new is on the UPS truck for Monday) and the DC ball joint was well lubed but VERY scored. It was eating itself and causing a metal on metal squeak.
Squeak turned to ugly, moaning squeak in 4-lo.
So, if you have a squeak, can't find or change it no matter what you do, and are losing your mind...check it out (assuming you have a Dc shaft).
