- Joined
- Sep 16, 2013
- Threads
- 2
- Messages
- 8
G'day. Im new here but hoping to gather as much information on what I was told is a rare Toyota transfer case as I can get!
What I have is a transfer case that has come from a FJ60 2F 4 speed. I got the vehicle purely because it had a Fairey Overdrive in it.
However, when I picked it up, I looked under and to my surprise, there was NO Fairey overdrive of the type I was familiar with
The type I am familiar with and know about is the separate Fairey unit that bolts onto the back of the transfer case
This transfer case is longer toward the back, and houses the Fairey overdrive Inside the transfer case with the overdrive selector leaver mounted to the top bolts that attach the transfer case to the gearbox.
On calling a mate who wrecks a few Landcruisers he told me he knew of these but hadn't seen any and felt it was a rare transfer case that Toyota made prior to the 5 speed gearbox being introduced but after the 55 which also used the bolt on Fairey overdrive on it if fitted, other models also used the Fairey overdrive .
My aim is to attach this transfer case to my HJ60 2H 5 speed gearbox to enable me to split each gear as I tow a 22 foot caravan.
I'm after ANY information at all on these transfer cases, also what if any problems others feel I will or may encounter putting this transfer case WITH integrated Fairey overdrive onto my 5 speed gearbox.
. This transfer case is longer toward the back, and houses the Fairey overdrive Inside the transfer case with the overdrive selector leaver mounted to the top bolts that attach the transfer case to the gearbox.
