Thanks again for posti'n some pics for me ,
In Aust we can run soa 4 wheelers no probs as long as a engineer has signed the work off once its complete which is generally pretty easy , although the job still has to be done right and structurally sound.
The rear glass in our 60's have rear sliding windows so that makes it a bit easier but cause you have to cut through the window frames its too much work to join them back again ,some people do but i wont i will be using polycarb easy to put in and cheaper than custom glass.
And i havent taken it for a drive yet but its charecteristics will be the same i have not altered any cross members or chassis so i reckon it will be the same , apart from Bigger rock faces to drop of , and bigger hills to climb !!
I have started a soa conversion on it now , and also i am going to grind of the sills below the dorrs the full length of the car which will give me 4" of clearence more ,and thenput on some custom sliders.
Also i will gain an extra 6" of lift almost straight away when i have finished the soa but then i will start to play with the leaf packs to get a longer almost flat spring to lower the centre of gravity back down.
Its all too easy !!!!
And s*** loads of fun !!!!!!!!
Cheers Olly
