I have my "new" 1979 wired and the windshield wipers working. I did re-wire the motor but I suspect that it was dirty brushes that was causing me nightmares as it worked, put it in a box for six weeks, time to install and nothing. Took the motor to a shop, he fiddled with it for a few minutes, voila, two speeds. At home it ran for a moment and then stopped not to start again. So I knew the armature was good, the commutator was good and the brushes have lots of life. So I suspected a weak wire and re-wired it complete. After the first, second and third time it was apart I cleaned the commutator, wrapped fine sandpaper around it and turned it by hand to "seat" the brushes. This time I took my Xacto knife and lightly scraped the brush faces. Anyway, everything worked. So I was finishing up, watching for repetition on the park position and noticed a wobble at the motor. There is a bushing on the shaft and it was coming out of the housing. I was able to washer up behind the linkage arm and tighten the nut, bushing can't come out now. Then I noticed a wobble on the right hand wiper at the pivot through the cowl. Off come the arms and I tighten the nut. Now my question for the Mud crowd.
1) I adjusted the limit screw and nut on the end of the gearbox to contact and backed off 1/2 turn and locked the nut. I found no specification for what the correct adjustment is. Does this sound appropriate? I will "assume" the idea is that the motor shaft doesn't walk much but you don't want it tight either.
2) On the left hand linkage the support bracket has two ears that protrude into the dash area. I note that on the "left" sweep a tick is heard as the linkage hits this bracket, not on the right hand side of the bracket. This bracket can be rotated with the outside nut loose. What is the correct setting?
3) On the right hand linkage the bracket does not have ears. On the cowl itself there is a boss, probably just a piece of sheet metal spot welded to the cowl. It is horizontal. When I tightened the nut on the outside and was back inside watching for any wobble I noticed that my bracket was at an angle and contacting the bottom of the cowl on the left side rather than horizontal. There is nothing other than nut pressure that would position/hold either of these brackets. What is the correct position/tightening.
And by the way, that Coolerman correction for the Toyota wiring is spot on with regards to switching blue/white and blue/black.
