My rear heater hoses were pretty grimy and were getting dirt on my new durabak
so I cleaned them up with some acetone on a rag but they still didnt look too nice with primer overspray on them.
So here are some pics of them covered up with some expando sleeving and heat shrink
looks a bit better now
The sleeve expands when you push on it and shrinks when you pull it from each end, I had some heat shrink just the right size so lucked out. Cut the expando so it hangs off the end of the hose to slide your heat shrink on easier If you want to reuse the orig clamps then cut it back behind where the clamps go for an easier fit cause the clamps are real close to the hose size.
