OK, i recentlty bought a none running 80 fj40 from one of the guys in our club. It was a driving vehicle when he bought it and then he let it sit for 6 months and he couldn't get it back running. He thought it was electrical problems cause the previous owner before him did a real hack job to the wiring harness. So over the last month i have removed wiring harness and replaced it with one from a later model 1980 harness. Everything fit perfectly with the exception of the section that goes from the passenger firewall to the engine bay. So i (atleast i think) repaired that section that the previous owner hacked up and it plugged in to the harness i put in. I made all my connections to the alt, coil, dizzy, cable from the starter to the battery, and couple more. I then only plugged in the section that goes to the instrument cluster and ignition. I check all the fuses and they are good. I put in a new battery and i tried to start it and i got nothing. Not a hum not click notta. I don't have a OEM manual and i am going from what i know and what i have read on here. I even have all the lights plugged in and those don't work so i am thinking i missed something somewhere.
Now the only think i can think of is that the PO desmogged the rig and i am still running the emissions modulator and so forth. Does anyone have a suggestion where i should look?
