I'm in the garage putting the timing cover onto my '75 2F and I can't seem to find a thread on this process. I had printed out the instructions along with the torque specs for the bolts a while back but now can't find them. Everthing is assembled, I just need the torque specs for the bolts. I found the specs in the Misc. Torque Specs thread but it says the 14mm bolts are 18 f/lb and the 10mm bolts are 43 i/lb (inch pounds!) I don't have anything that measures inch pounds. What else could I use to gauge torque for those bolts? Thanks.
