100 TD said:An auto reset 20 - 30 amp circuit breaker, connectors, heavy duty power supply cable to the prodigy, and then from the prodigy down to the back of the vehicle to the trailer connector, I would recommend 8 gauge(minimum 12 gauge), also if you have a standard trailer connector loom that plugs in to the vehicle harness, be sure to replace the earth wire in this loom with 8 gauge wire and hook up to a suitable earth point on the chassis, also if the plug in loom is pre-wired for electric brakes, replace this brake wire with 8 gauge as well. The reason being that the earth wire and brake wire(if it has it) will be about 20 gauge and cause voltage drop problems. (Also ensure you vehicle has a decent earth wire from the battery or engine to the chassis).
wngrog said:He said "earth" wire
ppressle said:I also installed the prodigy inside the ash tray. I carved it up to allow the controller to fit inside the little tray. Totally reversable, and it is out of the way, yet available for working the brakes manually.
Pete
DMX84 said:I used Velcro to mount mine below the steering wheel. I did this “temporarily” trying to decide on the location before I drilled the holes in the dash. But it holds so well I forgot about mounting it! lol.
Where are you guys mounting the trailer harness, under the bumper? I hate mine down there; it gets hung up when going over stuff. Any suggestions on an alternate location for my 7 way plug?
Thanks,
DMX
