- Joined
- Feb 23, 2005
- Threads
- 16
- Messages
- 1,081
On the 100, at the same time you switch the headlights from low beam to high, the front fog lamps will go out, I am assuming for safety reasons..(fog lamps are not needed w/high beams due to the reflection of light back to the drivers eyes...
Does (or has) anyone know of a way to disable this feature so that the fogs stay lit even when the high beams are engaged?
I realize that virtually ALL headlight functions are ultimately controlled by the instrument ECU and the DRL relays, but do you think its possible to "trick" the fog light system into thinking the lows are still on, not the high beams ??
ANY input is appreciated !!
