Lower Ball Joint - Questions
Oriental, NC
It appears I have an issue with my driver side lower ball joint. Can it be removed and replaced vs replacing the entire arm? How many banana job is it? How much does a lower ball joint cost? I knew I should have taken the easy trail to the mall. Thanks.
Could I just reboot it?
Yes. Toyota sells a boot and spring retainer clip. About $5 IIRC. FWIW: My lower ball joint boot was ripped. The ball was rusty in appearance and what little lube was left in the ball socket cavity was badly contaminated. I cleaned the ball and socket thoroughly with brake cleaner before assembling with the new boot and fresh grease. It held up fine.
