Hey all just a heads up and a warning. If you have no clue how to drive in snow and ice then just ignore this thread. If you do live and drive in snow and ice then listen up if you own a LC-100 or Lexus.
I have lived and worked in Alaska for my whole life and drive in snow and ice most of the year. (work on the north slope as well) I just purchased a 2000 Land Cruiser and love it. The thing I did NOT KNOW is the VSC system. This is a great setup that controls skid or vehicle side movement when the vehicle looses traction and brakes a line per say. If you live in normally cold weather or Arctic conditions this happens all the time. I have not driven this vehicle in ice or snow yet and found out real quick this thing (VSC) thinks it can drive better than I can...
I am here to tell you that if you start to slide you turn your steering towards the direction of your slide and this will level out the vehicle....whatever you do DO NOT BRAKE. So here I am going 45-50 MPH in a 55 and I slip a little (totally normal if you live in Alaska) and I do whats natural......turn towards the slide.
If this sounds nuts to you got to an empty parking lot with lots of water or ice on it and try. It will keep the rig straight and you can correct the slide..
So I turn towards the slip...a very minor slide and the truck brakes and powers up the wheels to the direction of my turn. I didn't realize this but what is a corrective action for me is seen as the direction the vehicle thinks i want to go. Two seconds later BAM into the guardrail.
So here is a recap.....if you are using VSC and are driving in snow and or ice and you start to slip and know how to correct this because you are a great driver and need no computer telling you how to drive then watch out. Otherwise if you start to slide do whats unnatural for us Alaskans and turn away from the slide and let the VSC take over and pray it doesnt brake to hard. I am looking into disabling my VSC without loosing my traction control and activating my diff lock. If anyone has done this by all means let me know.
Robert
Robert
It had the early anti-lock brakes and they wouldn't "lock" in the snow... I was doing 5 mph and they didn't even slow me down!! The true definition of anti-lock means they won't stop you because to stop they have to lock at some point.
So after the fence stopped me I pulled the fuse on the ABS and no more problems. Sometimes technology gets in the way of a good driver.
