Odyssey PC1700 MJT battery install
When I installed my JD lamps the other day I had to remove the battery. I noticed some corrosion under the plastic battery tray. After cleaning up the mess and re-painting the bare metal, I decided to get rid of my wet cell battery. (As it turned out, it was starting to fail anyway.)
After searching here through all the information about batteries, I decided to go with the Odyssey PC1700MJT (like some of you).
I wanted the posts in the original position for ease of installation & wanted something with larger reserve.
After the battery arrived I knew I was going to need a spacer underneath to compensate for the height & allow the hold-down work properly. After studying the new battery I noticed the factory hold-down wouldn’t “grip” like it did on the original battery. See photo. Also, in the picture the hold-down would put pressure on the weak plastic center portion of the battery and wouldn’t hold it very tight (IMO).
I made the spacers out of 3/4 delrin, the bottom (13.5x7.5) and two top spacers (3.9x1.5) to fit in the notches on the top. See photo.
The overall height is near perfect to the original & holds the battery very solid with the pressure being applied evenly on the strong portion of the battery.
I’m sure any 3/4 material can be used; I just wanted a clean look & delrin machines nicely!
Oh yea, if your hold-down is corroded like mine was, now’s the time to sandblast it and have it powder coated.
DMX
DMX
