Warn M12000 Wiring
Metro NY
I'm going to be fusing my winch and I want to be sure I am understanding WHAT exactly to fuse (please note that my controller box is mounted under my hood.)
If I fuse the positive from the battery to the controller I am good... right? That will protect the wire from the battery to the controller and the wires from the controller to the winch itself... right?
Yep, you are correct...any idea what size fuse you are gonna have to put in there?
Warn states max draw of 440 amps... I am going to use a 500a fuse.
http://www.donrowe.com/accessories/fuse_anl.html
I imagine that the real world draw seldom approaches 440 but I wouldn't want to have the fuse blow during use. The fuse is really for a catastrophic situation where one of the wires shorts to ground - like in a front end impact. I have the wires from the controller box to the winch running through the diagonal x members under the radiator and then up behind the winch mounting plate. it would take quite a bit but if one of those got pinched and shorted it would be certainly ugly.
