LinkBack (22) Thread Tools Display Modes
Old 02-02-08, 11:16 AM   #121 (permalink)
takeitforgranite's Avatar
Originally Posted by kevinmrowland View Post
Which hatch? The one between the seats? That one is a marine hatch I found online, hard to find in black.
I've found those online... I was wondering more about the tailgate hatch and the rear over-fender hatches.... plywood?
_____________________________________________
Yeah, I look like a grandpa driving it, but I still pull chicks.
84 FJ60 - 2F, 301k miles, 4.5" Alcans, 12" Bilstein 5150s, 35x12.5 XTerrains, Blazenoffroad.com winch bumper, magnaflow, rust, and an oil leak!
takeitforgranite is offline   Reply With Quote
Old 02-02-08, 11:51 AM   #122 (permalink)
beauty school dropout?
RockDoc's Avatar
TLCA# 18148
Check the links in post 5.
[ ][ ]=TOYOTA=[ ][ ] - 3FE and rust - Wobble Wagon
[ ][ ]=TOYOTA=[ ][ ] - 2FE and no rust, in the works
Edmonton area Cruiser Corner
Peace Canyon Toyota Swamp Donkeys
Today's lesson: You can't teach others, you can only facilitate their learning.
RockDoc is online now   Reply With Quote
Old 02-02-08, 12:14 PM   #123 (permalink)
Supporting Vendor
kevinmrowland's Avatar
TLCA# 14896
Ah, those hatches. Yup, I made those.
Side panels
Tailgate
1985HZJ60 ROTW Questions? Check out my Vendor Forum.
kevinmrowland is offline   Reply With Quote
Old 02-02-08, 12:19 PM   #124 (permalink)
canadianmedic2's Avatar
Someday, I want my truck to be a fraction of yours. Sick ride.
Owen VA7EHS
88 HJ61 VX with toys
EBI is the ONLY cruiser shop!
http://www.extremebends.com/
canadianmedic2 is offline   Reply With Quote
Old 02-04-08, 09:24 PM   #125 (permalink)
wyomingben's Avatar
If you don't mind I have a few questions.
1. The door weather seal, where did you source that and how can I get some. On mine any kind of a cross wind blows right in.
2. Can you explain the cargo net on the head liner, where did you get it and how did you attach it.
3. The expanded metal on your front bumper, what size is it and does it effect the brightness of your lights.
4. Why do you use a clevis instead of a hook on your winch?
5. I like your seat on seat sleeping idea, did you modify the hold down straps so you don't need a socket and ratchet to change from upright to sleeping? and in sleeping mode does it just sit on the bottom seat or do you secure it somehow for traveling.
Thanks!
-Wyo
wyomingben is offline   Reply With Quote
Old 02-05-08, 07:10 AM   #126 (permalink)
Supporting Vendor
TLCA# 14896
I had the same issue, wind gusts from the side were so loud, it was ruining the driving experience.
I had the trim custom made by a company we use at work. Since it was a custom run I actually had to have an entire roll made. (yeah, the noise pissed me off that much)
I have a bunch left if you need some. I would have to look at the invoice, but I think it was under $2 a foot.
The cargo net is actually half of an elastic cargo net that McmasterCarr sells. The eyelets are actually drilled-tapped-lock nutted into place. The structural metal ribs are surprisingly thick, just enough metal to thread. I have since added more eyebolts and just used nutserts (did not have the tool when I first installed the net) but the original eyebolts are still holding after many thousands of miles.
The expanded metal is not actually expanded metal, it is a square pattern of rods, welded together and dipped in plastic. Just about perfect for the use, I think it was originally industrial shelving base, I found it in a dumpster. They do block some of the light, but I travel a lot of gravel roads and having headlights not get broken is worth the compromise to me. I used to just have a piece of expanded metal zip-tied behind the grill to help protect the radiator from flying rocks, that worked well, but this is lighter and covers the lights as well.
The clevis is just personal preference. I find that the clevis makes you slow down and do things right, make sure things fit, is inherently stronger and safer than a hook and it stands no chance of disconnecting when the line is slack. I just don't like hooks.
The lower brackets for the seat have simply been removed, when the seat is up it is wedged in place between the seat base and the cargo boxes. Originally I planned to run a turnbuckle or strap to the floor for the seat down position, but since the top pins are set back from the top it locks itself in that position by way of the two extra latches and leverage. Even if I pull up on the front of the seat (when folded flat) It will not go anywhere since the back (top) levers down against the wheel wells.
Old 02-05-08, 08:07 AM   #127 (permalink)
wyomingben's Avatar
Kevin,
I would definitely be interested enough of the that weather seal to do my 60 if you have some to spare. About that cargo net, see those big red topo maps you have behind the seat, I was thinking of some way to store them overhead with bungees or net, ever consider that? Thanks for all the other tips as well.
-Wyo
Old 02-05-08, 08:15 AM   #128 (permalink)
Supporting Vendor
TLCA# 14896
Sure, I looked up the invoice, just a tad under $2foot, I'll call it 2 for simplicity.
I don't know exactly how much I used, but I will measure it tonight.
Old 02-05-08, 10:50 AM   #129 (permalink)
Ducks's Avatar
TLCA# 17334
I'd also be interested in the weather seal if there is any left over.
Ducks is offline   Reply With Quote
Old 02-05-08, 02:45 PM   #130 (permalink)
Supporting Vendor
TLCA# 14896
I'll measure the stuff tonight, probably getting pretty close to the end of the roll with the folks who just PMed me as well.
Old 02-05-08, 03:07 PM   #131 (permalink)
ColoradoLC's Avatar
Hey Kevin, great writeup. I remembered chatting with you shortly after your Artic Circle trip. Your rig was inspirational to me at the time even before I knew about all of he mods you have done. Well done. I have a buddy that organizes everything he owns just like you do. He lived out of his Isuzu Trooper for months at a time near Jackson WY when working there.
You have further inspired me past the point where I was already inspired. Thanks!
1986 FJ60 - Rear discs, JK Custom front bumper, 33x12.5 BFG ATs, Land Cruiser bottle opener and a whole bunch of other things - For Sale
1997 FZJ80 - 295/75-16 Nitto Terra Grapplers - OME suspension
2000 VW Passat - Very much not stock
ColoradoLC is offline   Reply With Quote
Old 02-06-08, 08:08 AM   #132 (permalink)
Supporting Vendor
TLCA# 14896
Thanks Colorado, did you make it up the Dalton yet?
Weatherstrip:
Mud wouldn't let me log in last night, or this morning, so I just posted the pictures on my website (saves Woody some server space anyway).
wagongear.com
Old 02-06-08, 09:17 AM   #133 (permalink)
Kevin - If you have dispersed all of your weatherstrip could you post the contact info for the company you used? I bet there are enough interested people that a group buy might be in the works.
Rob Faucett
Seattle , WA
87 FJ60
Rob Faucett is offline   Reply With Quote
Old 02-06-08, 11:04 AM   #134 (permalink)
Supporting Vendor
TLCA# 14896
The company is Trim-Lok,very well known, make a lot of OE stuff.
The problem is that you need an account and a shipping account to be able to order from them.
I am pretty busy at the moment with the other WagonGear stuff, but if there is enough interest I will consider ordering another roll. I also might be able to get a lower price if I get a longer roll as well, since I conned them into running this for me as a "test".
Old 02-06-08, 11:18 AM   #135 (permalink)
woytovich's Avatar
TLCA# 8334
Garage
KEVIN: I have a client that makes weatherstrip. If you get me the cross-section and specs I can see what he will do for me...
Mark [ mark@woytovich.com ] Metro NY
Founding member, Gotham City Land Cruisers
85FJ60 ~ 78ishFJ40 ~ M-416 ~ Trillium 4500
woytovich is offline   Reply With Quote
Old 02-06-08, 12:11 PM   #136 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
If one of you guys can set that up, then I'm sure you could get many people to buy this upgraded weatherstripping. I know I would.
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
GLTHFJ60 is offline   Reply With Quote
Old 02-06-08, 12:52 PM   #137 (permalink)
boots4's Avatar
TLCA# 19547
Me too.
build-up: Family Haulin' FJ60
boots4 is offline   Reply With Quote
Old 02-06-08, 01:32 PM   #138 (permalink)
Interested.
Rob Faucett
Seattle , WA
87 FJ60
Old 02-06-08, 03:16 PM   #139 (permalink)
Supporting Vendor
TLCA# 14896
I'll post the specs up, if your guy can get you a good deal that would be great, I certainly don't get any special pricing on the stuff.
I do know that the quality of the TrimLoc stuff is top-notch though.
Ideally the specs would be the same as an FJ62 front door weather strip, just with a larger foam-rubber bulb. The stuff that I have does not have as deep of a U as the OE stuff so it doesn't go on quite as far.
It is a huge upgrade though, especially now that my truck can go fast, no more wind whistling in my ear!
Old 02-06-08, 11:23 PM   #140 (permalink)
wyomingben's Avatar
Looking over your pics again, what do you use for a jack? If you tote a hi-Lift where do you stow it?
-Wyo
Old 02-06-08, 11:58 PM   #141 (permalink)
Dave-T's Avatar
TLCA# 16951
Simply an amazing truck. I really enjoyed reading the Toyota Trails article about one of your trips.
How much modification did it take to get the Impreza seats in there?
1984 FJ60---Hi-perf 2F with other goodies
2005 Subaru Forester
1994 Honda XR600R
2003 Polaris RMK 800
(@)==Toyota==(@) <----- 60's rule!
Dave-T is offline   Reply With Quote
Old 02-07-08, 07:53 PM   #142 (permalink)
Supporting Vendor
TLCA# 14896
For the folks who have weatherstrip coming, They are boxed up and will leave in the mail tomorrow.
I am pretty swamped right now, but if the people who get weatherstrip are as happy with it as I am then I can just order another roll since there seems to be plenty of interest.
Now, no more weather strip talk in my ROTW thread.
-Wyo
I primarily use the OE bottle jack (which lives in the passenger quarter panel) since it is safer and easier to use. The high lift lives across the floor behind the seats when it is in the truck.
The seats where originally mounted to the stock towers. The modification was not too bad, but I did have to make custom legs. Now with the underseat boxes the seats just bolt right to the lids.
Old 02-07-08, 08:23 PM   #143 (permalink)
Ducks's Avatar
TLCA# 17334
In the Toyota Trails article, you mentioned that the rear was sagging. I can't remember, did you have more leafs added to the rear? Was it the OME heavies that you modified or are they new since the trip? Have you considered air bags?
Old 02-08-08, 07:27 PM   #144 (permalink)
Supporting Vendor
TLCA# 14896
That trip was a pretty long time ago, I had some crappie springs that I paid WAAAY to much for from $OR. (I have that reaction to everything I bought from $OR)
I had two heavy add-a-leafs made at a spring shop and went from there. As soon as we got back (and got money back in the bank) I ordered a set of OME and have never looked back. The OMEs seem to be built for my purpose, I haven't needed to think about air bags since.
Old 02-08-08, 08:21 PM   #145 (permalink)
TLCA# 18410
shifter lock
great ride. i am interested on the shifter lock. where did you get it and how much did it cost?
Dan
1983 fj60 Aussie rear locker, custom front and rear bumpers and sliders, custom aluminum rack, OME heavy with 33" super swampers
1978 fj40 hard top stock in stance right now; 31 allterains...bumpers to come
http://forum.ih8mud.com/60-series-wa...-build-up.html
http://forum.ih8mud.com/40-55-series...ml#post4188612
cfdlighthouse is offline   Reply With Quote
Old 02-08-08, 08:34 PM   #146 (permalink)
Rollin‘ on 33s...
macneill's Avatar
TLCA# 12733
Beautiful!
Thanks for the inspiration!
1981 FJ60 - 210K, OME, 33" BFG ATs, Surco Safari Roof Rack with custom Rod Racks, MAF header, Flowmaster Super 44 muffler.
2002 UZJ100 - 50K, OME 865, OME T-Bars, Slee Diff Drop, TJM T-15 AL, TJM RB8, TJM Rear Tyre Carrier, Toyo OC ATs, Warn Winch, AO Roof Rack, IPF 900s, PIAA 520s and 510s, Borla CAT back with SLP muffler.
Yankee Toys
Bay to Blue Ridge Cruisers
macneill is offline   Reply With Quote
Old 02-09-08, 07:55 AM   #147 (permalink)
Supporting Vendor
TLCA# 14896
Dan
Great product, got it here: http://simjack.com:8185/
$55, I was amazed at the quality of the product for the money, and being the constant cynic that I am, I figured the lock must not actually be hardened, took it to my metal band saw, and nothing, couldn't even scratch it.
Old 02-09-08, 03:40 PM   #148 (permalink)
sandcruiser's Avatar
I sense a group buy in the near future
91 fj80 w/ 93 1HD-T. OME 850/860 w/ 1" front spacer, LEDs, HIRs, Geolander MT's 33x12.50r15, Tuffy center, ARB rear locker (in progress), in garage: lightforce lights, full rack, superwinch X9, maggiolina tent, hella horns.
ask me about Costa Rican Realty
sandcruiser is online now   Reply With Quote
Old 02-09-08, 03:53 PM   #149 (permalink)
Supporting Vendor
TLCA# 14896
I thought it was your truck that I first saw the shift lock on?
Old 02-09-08, 05:36 PM   #150 (permalink)
woytovich's Avatar
Turns out these guys, simjack, are just a few miles from my house. I am going to contact them on Monday regarding a group buy/dealer pricing. If I get anywhere I'll post back here and start a new group buy thread. Probably can't save much but $5 or $10 off is better than full price...
I'm buying one in either case.
LinkBack to this Thread: http://forum.ih8mud.com/60-series-wagons/200578-rotw-kevinmrowland.html
Posted By For Type Date
Truck Tent - Front Range 4x4 Forums This thread Refback 08-31-09 01:26 PM
Cracked cylinder head questions - ToyotaDiesel.com This thread Refback 07-23-09 01:32 AM
Spare fuel swing down - Expedition Portal Forum This thread Refback 07-21-09 02:08 PM
Curious - Front Range 4x4 Forums This thread Refback 03-21-09 09:22 PM
Íàðîä Ïîäñêàæè - Ôîðóì Offroadmaster.com This thread Refback 03-18-09 03:59 PM
Fridge Hinge Flip Kits from Wagon Gear - Front Range 4x4 Forums This thread Refback 03-08-09 10:27 AM
Search This thread Refback 01-31-09 06:15 PM
Post up pictures of your in-vehicle digs... - Page 2 - Expedition Portal Forum This thread Refback 01-28-09 09:53 PM
LRover vs LCruiser? - Page 5 - Expedition Portal Forum This thread Refback 01-14-09 11:52 AM
Sweet toyota build up! - Front Range 4x4 Forums This thread Refback 08-30-08 02:59 PM
Building up my rear cargo area...few questions - Page 2 - Expedition Portal Forums This thread Refback 08-28-08 07:28 PM
Trips This thread Refback 07-27-08 06:11 PM
Project Galleries This thread Refback 07-27-08 06:04 PM
Home This thread Refback 07-18-08 04:52 AM
Project Galleries This thread Refback 07-03-08 11:57 PM
Kavik OffRoad...WagonGear This thread Refback 05-08-08 03:19 PM
Storage for 60s - Rising Sun Member Forums This thread Refback 03-17-08 11:54 AM
Post up pictures of your in-vehicle digs... - Page 2 - Expedition Portal Forums This thread Refback 03-15-08 08:50 AM
Post up pictures of your in-vehicle digs... - Page 2 - Expedition Portal Forums This thread Refback 03-15-08 08:13 AM
ohh condensation - Expedition Portal Forums This thread Refback 02-24-08 03:21 PM
Home This thread Refback 02-16-08 10:49 AM
Trips This thread Refback 01-23-08 06:56 AM
