So, I know to many this is old technology but thought I would try it out as I had a space where my unused york was sitting and thought it would be cool to have a stick welder on my FJ40. Plus, I didn't want to spend the ridiculous $$ to buy an aftermarket onboard welder. All in all, I spent about $150 and this could be done for even less if you were to get a junkyard welder. I just decided to purchase a 100 amp reman unit from the local parts store. I then had to buy a little scrap c channel, positive stinger from harbor freight, negative cable from harbor freight, an led switch and some wiring. Super simple setup, hardest thing was the bracket setup. Basically the alternator is an externally regulated alternator from a Ford. You need to put one wire to the "field" tab on the alternator and wire this to positive / fused source. This "energizes" the alternator. The switch is there so there is not a constant power source going to the alternator. Flip the switch, attach the cables and weld. Let me know if anyone has any questions!
Noah
first pic is the old york area cleaned up, the alternator is mounted where the AC compressor used to be, this is a 99 vortec engine.
Noah
ingtastic!
