- Location
- United States
TX-1 Offroad Wheels - different sizes
I'm going to order a few sets of TX-1 wheels from Australia. Formerly known as Outback TX-1
Available in a wide variety of sizes and applications, tubeless performance industrial wheels are lighter than conventional steel wheels, won't rust and are load tested (3086lbs per rim) to provide maximum rugged durability
These are the available spec so far, but if you are interested in other sizes and bolt pattern, let me know and I'll ask the factory
They are available in white, silver and black
15x7
6 on 139.7mm
-4mm offset
8.6kg
67mm to 108mm hub bore
16x6
6 on 139.7mm
-6mm offset
8.8 kg
67 to 108mm hub bore
16x7
6 on 139.7mm
-4mm and +4mm offset
9.07kg
Edit: Additional sizes
14x6 (+8mm offset)
15x10 (-52mm offset)
16x8 (+3mm / -7mm / +20mm offset)
16x10 (-27mm offset)
17x8 (+3mm offset)
The rims itself are actually not that expensive, but obviously the shipping from Australia is not cheap. It depends how many people are interested. 4 rims including shipping (to Vancouver, BC) are about $750 - $900
Let me know if you want one too.
15x7
6 on 139.7mm
-4mm offset
8.6kg
16x6
6 on 139.7mm
-6mm offset
8.8 kg
16x7
6 on 139.7mm
9.07kg
14x6 (+8mm offset)
17x8 (+3mm offset)
