Zero-rust on springs?
The Rockies or the Andes
I have disassembled stock spring packs to drill the military wrap leaf for a spring reversal. Before I reassemble I am going to sandblast and paint them. I know there is a special graphite paint out there for this but I have heard bad things about it. Has anyone used zero-rust on thier stock leaf springs?
A search for "paint springs" will turn up some good results. e.g.: https://forum.ih8mud.com/showthread.php?t=68833
I am about to do 2 coats of POR-15 then 2 coats of POR Chasis Black. The Chasis Black has flexibility characteristics that make it a good choice for springs.
I would check the flexibility factor on the ZeroRust; otherwise, I can't imagine why it wouldn't work. I would then use a lubricant between the leaves (if you have them apart) to have them ride best.
HTH
B
The zero-rust should be OK, but any coating will abrade off between the leaves. Rust will develop with consequent squeaking.
i've never done it, but I was using a good marine grade grease for something else yesterday and the can touted it's ability to stay put in adverse conditions. Might be just the thing between spring leaves.
I know that I've seen several people say that the aftermarket nylon/whatever spring insulators don't stay in place for long or disintegrate. (The OME yellow pads not included in this- they work)
