I purchased the car about 7k miles ago, it had about 98k at the time. The drivers Birf had some grease splatter around it, the passenger was a little wet, but not splatter. At about 102k miles, the passenger Birf had some splatter. I noticed last week that both birfs were dry and even had a little rust forming on the knuckle. Trying to put off a front end job for a while, I decided to pump grease in them and check the diff fluid. My understanding is that the splatter is caused from the seal going bad, mixing the gear oil with the grease and thinning out the grease. My diff is full, of GREEN gear oil, whats up with that? The grease that I could get on my finger from sticking it in the birf fill hole was regular old black grease color. The gear oil smells fresh and doesn't show any signs of having grease in it, which makes sence to me because the oil is thinner and should leak into the knuckle, not the other way around.
Do the birfs just naturally over time use grease to the point that mine would be dry with 105k miles on it?
Thanks
Andrew
Thanks
Andrew
