YHS (Yellow headlight Syndrome)
Paso Robles, CA
Yes, my 80 is starting to get jaundice in the drivers side eye. Probably due to a microscopic crack in the lens somewhere. The passenger side eye is still clear. I gave it a look, and it appears that the lens is glued onto the rest of the headlight assembly with some sort of perma-bond. Anyone have any ideas? Can do you lens replacements on these rigs without having to replace the entire headlight assy? If I throw a heat gun at it, will it melt the perma-bond and allow me to at least clean the inside of the lens? Cheers:beer:
IIRC you can toss it in the oven to heat up and soften the bond, and then take apart, clean, and put back together. Try searching some of the HID threads, think the details are in there.
The lens is glass, so most likely not yellowing, probably just dirt? When I sank my rig, poured the mud out and cleaned with water, ice and shaking, then rinsed with purified water and some dishwasher anti spot stuff, worked well.:hillbilly:
My driver's side housing was getting "dirty" looking inside as well.
I heated it up in the oven, disassembled, cleaned, and re-sealed
carefully. It's wierd, 'cause my passenger's side looks like new.
JJ
If you have too small an oven or don't have access to one (Who wouldn't?:hillbilly:) you can get a cardboard box just large enough for the headlight, cut a hole just large enough for the tip of yoru hair dryer and blow into it for 15-20 min.
It got the goo soft enough for me to separate the lense and the housing.
Do it at your own risk though! :hillbilly:
Good luck!!
My drivers side leaked to. I took it apart and cleaned it, but the damage was done. The water that leaks in ruins the reflective material on the reflector.
Dumb question, but what temp should I set the oven at?
You get different numbers from different people.
Also some people like to toss them in from the get-go, while others let the oven warm up, turn off, and throw them in, etc...
I would do it low and slow. You can always take it out and check it out. If not coming apart, you can leave it in longer or bump up the temp a little.
Good luck!!
I wouldnt do the oven trick, too risky for me. My tabs were broken on mine, so I sourced some used ones with broken glass. Used a heat gun to melt the goo and it works great. Once seperated, you can then use the heat gun to melt the glue on both the glass and the housing when puttng it back together. I would think the oven could possibly distort or melt the housing. But guys have done it. Your choice.
