Yet Another Headlight Thread...
Dallas, TX
I finally pulled the trigger to have my headlights retrofitted with HID in my 2007 LC.
For those that have done this; what do yall usually do for the high beams, parking lights, and blinkers?
The retrofitted HID use a bi-xenon projector, so am not for sure if the separate high beams still fire? If they do, i suppose getting a similar color temp halogen bulb would be best?
I also have read about people disabling their parking lights, what advantage does this give me?
And lastly, any issues with swapping my front/rear blinkers to LED? Assuming I will likely need a resistor to keep from hyperblinking?
TY
IF you don't have a pigtail to activate the HID highbeams and the OE than I believe only one will work. I did a bi-zenon retrofit on my WRX back in 2020-ish but I just had the one projector per side.
Diode dynamics makes a flasher relay that will fix hyperblink if you go to LEDs. Also offer a "Smart" version that gives you a little more functionality
Thanks for the reply! That makes sense. I did order the DD smart relay for the hyper blinker
