Yet another front end noise ques
tdfox
Rover31 Jedi Master
Central WA state
Yet another front end noise ques, update
Hello experts from a newish idiot. Just wanted to get that out of the way.
I am on my second 80. 1st one was sold for various reasons but I wised up and bought another... and love it.
Here is my ques... front end noise when turning at low speed, like leaving a stop sign and making a turn around a corner. Sounds kinda like a plastic clatter. Kind of what you hear when a CV joint is going out (yes I know these don't have CV joints that's not what I am saying, it just sounds like that). I am sure the rig is well due for a front end overhaul but is that sound indicative of anything else or a sooner than later procedure?
Rig has 115K no mods to the susp. Has Cooper SSTs on it (they work quite well!) It brakes, steers and runs fine elsewise, just this clattery noise.
If I am not being clear I can try using my telepathy powers to get you to understand but, they don't work so well these days. Yes I used the search engine no I didn't find what I thought matched my description.
Thanks in advance!
Travis
The Birfields are dry. Mine did that, and I ended up replacing the Birfs.
Yeah, birfs are dry or they've worn to the point of replacing or swapping sides.
Does it make a 'click-click-click-click' sound as you turn? That would be the Birfields.
Thanks
Judged by a jury of my peers. I must have dry Birfields!
Thanks for your help.
Swapping sides works? Is it worth it or should I just go for the replacement?
Thanks
Travis
update
been quite a while since I have posted...
here is the update
I had a local shop with a "good rep" do the front end this fall, new parts and all from CruiserDan (good guy).
The Cruiser doesn't get driven much until this winter and now when I drive it, it make the same clatter sound upon going around a corner.
What would this tell you guys? Did they do the work wrong or at all?
Comments please I am a bit ticked right now
Thanks
Travis
Did they service the axle (seals/bearings/repack) AND replace the birfs or did they just do the service (seals/bearings/repack) WITHOUT replacing birfs? If they just serviced the axle, it is entirely possible that the birfs are worn and need to be replaced as well.
I went through this several months ago. I did the whole axle service myself but did NOT replace or swap sides on the birfs because it was hardly making any noise (the clicking or popping). I am now about 8k miles since the axle service and the clicking has gotten REALLY bad since my service. I am kind of shocked because it was not making much noise before the service and they looked great when everything was apart, but the clicking has gotten progressively worse and is now really loud.
I am dreading having to tear the thing apart again to change the birfs....
crap that is not what I wanted to hear, course I also didn't want to hear the shop screwed me... guess they didn't... bummer
Thanks for the reply
