OK - Finally got around to fixing my leaking exhaust manifold. Got the air cleaner and carb off and started removing the bolts and nuts from the block. But, my rig is an 02/80 FJ40 with all the smog gear. This means I have the hardlines for the vacuum system running towards the front Driver's side and partially blocking the manifold for removal. Not sure if I have to remove - and if I do I have alot more notes to take (there are alot of vacuum lines there but I do have the FSM). Also have the EGR pipe and valve very close to the manifold.
So, any advice? I searched and read today and didn't see any related discussion on this topic. I'd just like to know what all I have to remove so I don't remove too much and create more work for myself or try and do it without removing enough parts and break something or cause more PITA labor.
I am using stock manifold (no headers) and have a new OEM manifold gasket which will go on dry (as per instructions). I also got new studs and bolts for when I re-install and new EGR gasket as well as the heat riser insulator and gasket. I will torgque to factory spec and then re-tighten after I drive it some. May go in a third time just to ensure all is well. Will use anti-seeze on all bolts. Did I miss anything?
TIA,
AndrewT
TIA,
AndrewT
