Yellow 'Check' Bulb is on
You need to pull the codes from the ECU (code reader or have AutoZone or similar do it) and see what caused it to turn on.
Hi DMX8 , thanks for the help. My TLC is now in a remote part of Asia where no authorized Toyota service centers are around. Can you give me some hints as to what can cause my Check Engine to light up ? So we can check them manually.... Thanks
No problem, it could be anything as simple as a fuel cap not sealing (turn it until it clicks) or anything on the engine.
You should purchase an OBD 2 code reader ~ $100 bucks and you will be set and this will give you piece of mind and the ability to clear the code and turn the light out.
Thanks for the advice..
Where can you buy one online for a decent price?
