Hey Ya'll
After I installed the 285s on my 97 Landcruiser, I borrowed a friends GPS and found that my speedo was off by 3 MPH (6% for those of you keeping score..)
After looking all over Mud and the internet I concluded the easiest and least expensive and most accurate solution is the Yellow Box unit. I was swayed greatly by Woody's write up with pictures (pics are easier that reading all those instruction!) and Romer's write up about making sure to order the correct unit of 3 wires instead of 2 wires for a 97 model.
A Toyota tech helped me to do the install to help avoid cutting the wrong line
It took about an hour and a half, mostly looking at Woody's pics and then rereading his direction, rereading the yellow Box instruction.....and then cutting. All that said, there is maybe only 10 minutes of actual labor. Once wired, I left a long pigtail for easy access to the unit and down the road we went. Knowing my percentage of speedo outage, we calibrated the Yellow Box. It was slightly off. Pull over, power off, adjust and wait 30 seconds. Start it up. I was dead on with the GPS! Stuffed the pigtail back in, wedge the yellowbox in with the other wires, and put the glovebox back in.
Alot of folks have said "If you know your off by 3 MPH, just remember that and adjust your speed." That's fine and dandy, but I like my truck to run right with everything working the way it should. Also, I spend a fair amount of time on the highway, and like to drive 9.75999 MPH over the posted speed limit with the thoughts that you don't really get pulled until you 10 MPH over. It's held true so far and its important to know your speedo is dialed in.
Lastly, the folks at Yellow Box were good to work with, the unit was easy to install, and the price was right! Good mod for those running larger tires and want to know their speed.
Emmett
It took about an hour and a half, mostly looking at Woody's pics and then rereading his direction, rereading the yellow Box instruction.....and then cutting. All that said, there is maybe only 10 minutes of actual labor. Once wired, I left a long pigtail for easy access to the unit and down the road we went. Knowing my percentage of speedo outage, we calibrated the Yellow Box. It was slightly off. Pull over, power off, adjust and wait 30 seconds. Start it up. I was dead on with the GPS! Stuffed the pigtail back in, wedge the yellowbox in with the other wires, and put the glovebox back in. Alot of folks have said "If you know your off by 3 MPH, just remember that and adjust your speed." That's fine and dandy, but I like my truck to run right with everything working the way it should. Also, I spend a fair amount of time on the highway, and like to drive 9.75999 MPH over the posted speed limit with the thoughts that you don't really get pulled until you 10 MPH over. It's held true so far and its important to know your speedo is dialed in.
Emmett
