Y pipe broken
Knee deep in hookers and gin
Probably a repost, but...
I had an 80 come in today with an exhaust leak. The leak was coming from the y-pipe joint, much like I remember AliA's last summer or so.
Both muffler exhaust hangers were broken, like most of them here in the rust belt, but the thing I think most caused the y-pipe break was the hanger that attaches the y-pipe to the bellhousing. The clamp fell off and caused all the weight of the cats to flex the y-pipe causing it to crack and rust.
After TIG welding the y shut, retapping the manifolds and putting in new studs, I threw a muffler clamp on the bellhousing. That sucker won't fall off.
Two universal mounts on the muffler and it was solid as a rock.
So check your y-pipe to bellhousing clamp. It's a really crappy design.
Or you can buy a new y-pipe. It's only $1200.
Yup $1200.00 for new Y-pipe or let me just add lil here or $1900.00 for the bling-bling JDM version but wait shipping and tax not included :grinpimp:
That's it only $1900?
Supply and demand is a bitch ain't it?
$1900 makes the Downy header look like a steal. I guess the $1200 stocker does too.
:beer:
But Downey headers are sold as Headers & Gaskets only, no down pipes from Header to catalytic converter (like the 2nd pic). You need local muffler shop to make mandrel bent or the converter connection for you.
Given the $1500 difference, I don't think that it will be all that hard to fab locally.
BTW, has anyone actually tried the Downey header? My exhaust system is shot and I have an emmisions test due in August.
PLEASE How can I get one of those for a '97 LX-450?
(will need international shipping)
A good local shop should be able to drop the pipe and reweld it for you. It needs to be a shop that does custom exhaust or reputable fab work. They need to be able to run a welder.
They also need to know how to get the nuts from the manifolds without breaking them. I would suggest they pull the manifolds (a very easy job) and re-tap the stud holes for new studs.
If you just want a new y-pipe, your toyota dealer should be able to round one up for you.
Why tap the manifolds? Are you changing the size of the studs? If not, then why wouldn't the studs either stay in the manifold or simply be removed and replaced?
Mine started leaking in the same spot, Just a small pin hole. I looked at the rusted nuts attaching it and decided that I didnt feel like dealing with it at the moment. I got some stuff called Thermosteel, which is used to patch holes in manifolds and shoved it in the crack. It has been working just fine for a couple months now. I live in the salt belt and I think my exhaust is on its last legs. I priced the parts at Toyota and about fell over. I will probably go to one of those custom muffler shops and have them put a stainless steel exhaust on it. When that time comes, I will probably ask them to weld the Y pipe or fab a new one. In the past, I have gotten rust in my eye and scratched my cornea while working on exhaust systems, so I dont mind paying someone to do the job now.
Mine had the same crack and my buddy just welded it last weekend - he had to take the Y pipe off the truck because the crack went pretty far over the back side of the pipe. I also found two more cracks - one inbetween the cats and another on the muffler. Now it's time for a custom exhaust and would really appreciate some pics that I could show to the shop that will perform the work. Please direct me to some if they are already out there (and I bet they are). Thanks.
