Y link conversion clearance issues
dixon, california
i have recently installed the over the knuckle gm one ton y link on my 80 and I’m discovering clearance issues with my Panhard. I knew I was going to have some touching in my land hard bar to my tierod which I wasn’t to concerned with because I was going to replace the Panhard anyways but now I discovered while hitting out large speed humps going in and out of my base I’m also hitting the Panhard bracket on the tierod. Is this normal? I have a OME lift kit which I believe is the 3 inch but I’m not positive because I bought the rig with it and the only I can find for number or markings on the springs is one rear spring has a tag on it that says “j”. Do I need to replace my whole Panhard set up on the front end and relocate it to the rear of the axle or will 1 inch spacers solve my issue until I can get the four inch lift from dobinsons like I want? I hope the pictures explain my issue a little better.
