Xfer case shifter v8
apple valley ca
Hi I'm a LS swap on 93- fj80. It has a 4l80 and marks4wd adapter to the stock xfer case. The xfer case shifter mount on the adapter is about 5 inches back from the original location. What do you typically do about this apparent misalignment?
What about tranny shift cable? I saw one guy said trailblazer. What year?
Thx, Mike
The transfer case lever alignment issue is well documented in the v8 swap thread stickied above. Usually you need to fab a plate to mount the shifter. Any mid 2000's year trailblazer cable will work for 4L60's ... not sure about 80s.
