x
counted a hub I have here, the rear abs ring has 48 teeth, so 48 cycles per revolution, the training manual says the sensors produce a low level AC voltage, one cycle (low peak, high peak) per tooth
It's nearly a square wave.
So is the VSS.
Problem is the frequency per revolution will be very different.
Also, if you try to use both WSSs therell be frequency overlap (like a flanger for a guitar) that'll confuse the PCM.
You could probably run one of thos VSS correction boxes for bigger tires and fool the PCM into thinking a single WSS is the VSS.
A lot easier than installing a VSS in the stock transfer.
Or, you could just get an 80 series transfer. It'd already have a VSS. :)
:eek::eek:
Uh, Houston, we have a problem.........
some of you guys are way too smart for us puny earthlings:flipoff2:
oh yeah, where're the pictures of this beast of a '55?
