I think most here on the board would agree that the weak link in the rear differential is not the 3rd member/electric locking diff. itself, but the splines from the full floating shafts.. That's what fails, they'll twist under extreme load/shock, and therefore break and cause a mess in the differential itself resulting in a 3rd member breakage....I do feel that 35's with stock shafts should be fine, as almost everyone on here now is running 35's..There all fine.. Like you mentioned before, the ARB differential is stronger, but the stcok Toyota diff. is plenty strong too...
