WTT 80 springs for springs and body lift
Status
Not open for further replies.
That is a lot of work for little gain. Yes, the COG of will be a little lower, but doubt if you will notice it much after you do the body lift. What is bugging you on the trail? Off-camber? If so make the truck wider.
You're right, and that's what I want to do. But with wheel spacers I get insane rubbing, so I'm thinking the body lift will allow me to go wider and not have as much rubbing as my current setup would. I'm also considering just buying your 4" rear springs and see if a stiffer rear coil will make it better.
Alkaline, Your headed to the hardcore off-roader realm. You need to learn how to use one of these;
Status
