that's pretty common since people have a tendancy to over-tighten those bolts. they're fairly small diameter so you can't go too heavy on them. but a drop of loctite is definetly a good idea.
i have a few extra housings, but brfore you buy one, try this trick.
take a 6mm nut or something roughly that size. set it on top of the broken bolt and weld the nut to the broken bolt. then put a wrench on it and the "new' bolt should unscrew.
if that does'nt work then lemme know and i'll be happy to sell you one.
hth
georg @ valley hybrids
