Wanted WTB Steering shaft
Kansastitty
I need the rag joint end of most any year shaft. Don't need the whole column, just the shaft. Doesn't that get discarded when doing a Saginaw conversion?
About a foot of length of the end that has the rag joint coupler on it would be great.
PM me if'n you gots:D
Ed
Steve came up empty......so.......TTT:D
have a bunch of those colums here can cut one for you all from rag joints can cut to fit flat rate box if that works dont have the rags though thanks
You mean the end of the shaft has the flange for the rag joint? If that is the case, just cut off about a foot or 15" and box it up. PM me with a price.
And thanks!
Ed
yes that is correct has end where rag bolts to it will measur flat rate box and get back to you unless you need it that long thanks
