Wanted WTB- four speed for 3B
WEST TEXAS
i want to buy a four speed transmission (H42?) compatible with 3B diesel to go in my 1979 fj40 conversion.
i have a 4 spd and "T" case that will do the job you want, currently behind a 1983 3B engine both complete with shifters........don't want to seperate the transmission and transfer case though...but i will for the right price.
$500.00 plus the ride
The engine is also for sale for an "ADDITIONAL" cost of $1500.00 plus the ride
(sorry to those that were confused)
shipping might be an issue
Best Regards
Gord
Got one here in Texas!
I am near Houston. It is in a daily driven 82 BJ-42 I am about to convert to 5spd.
Justin 281 483 8422
gord- this one is way closer.
justin- i will call you
Trans
Lynchmob may have the answer depending on your access to a shop. If you want to come drive this one please call and we can arrange a time.
Justin Wehring
281 483 8422
lynchmob i have an input shaft that colby1979 gave me. i will do the shaft change if i don't make a deal on a transmission.
depending on your cross member, a shaft swap won't work. You need the bolt holes in the tranny to bolt the mount to. Also, which t-case do you plan on running? different output shafts for different t-cases
You will also need to change out:
bellhousing, throw-out bearing & retainer, throw-out bearing fork and front tranny input bearing retainer.
Hope this helps
i have the engine, bellhousing, clutch fork, throw-out bearing and retainer and an input shaft. i do not have a input bearing retainer. i think i have some engine and transmission mounts coming from new zealand.
The tranny input bearing retainer from a 2F is to short and the OD is to big, your throw-out bearing hub will not fit. So you will need one from a B or 3B tranny.
Specter has them used for $$$75, 062-40AB-U
G'day
