wrong fuel
Many years ago I did the opposite while on an elk hunt. I wasn't paying attention to the pump, and filled the 40 with diesel. I got about 3 miles. Ended up at the side of the road draining the tank into the ditch (pollution, I know). Lucky I had a gas can with about 4 gallons of gas in it.
i cant believe how resilient these old motors seem to be. they get punished and just keep on trukin.
Now that you know it's a 2F, replace the fuel filter... it may be filthy and starving the carb for fuel.
How long did the previous owner park it, without driving it? You may need to drain and clean the tank... and the fuel lines.
If it has a PCV, pull it off and shake it. Does it rattle? If so, put it back on. If not, replace it.
It may need a tune-up (plugs, points (if it has points), valves adjusted, timing set, etc.).
I'm guessing, from your narrative, that the problem is fuel-system related... clogged filter, crap in tank and/or lines, carby gummed up, etc.
Was it misrepresented in the advert? If so, does that allow you to return it, for a refund?
Or, do you prefer to keep it?
yea i agree fuel is definetly on the to do list. carby leaks so going to rebuild when i hace some cash to spare.
noobie question. what is a pcv.
PCV = Positive Crankcase Ventalation
It's on the passenger side of the engine, almost in front of plug 6 (rear of engine)... (be careful the rubber grommet doesn't fall apart and down into the crankcase. Replace the grommet, if it's not in great shape.
The hose runs from the PCV valve to the intake manifold, below the carb.
It looks like this... it's a one-way valve... be sure you install it in the proper direction.
ok thx. i will look into that. i think maybe carby trouble as there seem to be no blockages because fuel is in the window and when gas is pumped base of carbie is wet from leaky gromet below window so fuel is reaching carby.
