Wrong Fan? Wrong Shroud? Help!
Wichita, KS
When I bought my '91 FJ80 it had a direct drive fan and no shroud, courtesy of the previous owner. Trying to make it right again, I bought a used fan blade and clutch from a Mud member. A while later, I bought a fan shroud from another Mud member. All parts were supposed to have been removed from a 3FE FJ80. The problem is, they don't work together. The fan fits fine without a shroud, but with the shroud installed the fan hits it. Either the fan projects too far forward, or the shroud shape is wrong. Other than the interference issue, the shroud tabs and bolt holes line up perfectly. None of the parts have PNs on them. Any suggestions?
In case pictures help:
Matt, it appears that you have the wrong fan clutch. The 1FZJ fan clutch has a longer snout, the 3FE is shorter, which would explain why it's hitting. When the sun comes up, I'll verify, but it doesn't look right.
It looks as if you have about an inch between the shroud and the p/s pump, which is right. That's the later fan clutch, which won't work. You are looking for a green hub Aisin. I have a spare, but it needs a fluid change. Let me know if you want it. It appears that you also have the wrong fan, which would explain a few things since you got the clutch and fan from the same person, right?
Edit: The FJ62 fan/ fan clutch will work on the 91-92, that gives you a few more years to work with when looking for the right parts.
What's the verdict on the shroud? Is anything right?
The shroud looks nothing like the one in my 96. The fan clutch looks like it has similar dimensions to the one on my 1FZ, so it might be the culprit.
X3, that looks like a 1FZ fan and clutch. The 3FE fans that I have seen are offset less to the front, slightly narrower blades and have little air deflector ribs molded into the ends.
Thanks guys. I will just price new parts, I'd prefer to avoid this PITA again. On the upside, the current fan works fine, and it's almost winter.:D
Are you sure about the FJ62 fan? I think they have different PNs.
