WOW!!!! Headlight swap WORTH IT!!
MrMoMo
That's not rust, it's Canadian patina...
~Kingston, ON, pero soñando de Panamá
Ok, I know some of the people here have done this swap, because MUD is where I got the part #'s. But for anyone who has been thinking about swapping to the SilverStar H6204ST headlights... DO IT!!! OMG!! If you do ANY driving at night it is an AMAZING difference. (NO, I don't work for Sylvana or have any association with them) Our Subaru Impreza has Silverstars in it, so I knew they were good, but didn't realize how much difference they would make in my 40. I paid $33/side CDN. Didn't shop around for the best deal, just bought them where I knew they had them.
I know, I know, useless without pics, I knew you would say that so I took some befores and afters. No tricks here, same camera, same settings, engine running, same idle speed.... no cheating!!!
Oh, and I corrected my Bezel at the same time!
HERE YA GO!!
Sure you don't work for Sylvana?
Great pictures sell the product!
nocents
looks good bruce............say what did you pay for that rig of yours?
thats a huge difference in lighting man.
Easy Easy Easy swap. remove bezel. Remove headlight retaining ring. Light will start to fall out, catch it. Undo plug. (ready... here you go) Assembly is reverse of removal but with new light instead of old one. H6024ST is the part #, that's all you need. Sylvana Silver Star. Not only a better light pattern, but also much whiter light. Photo shows my mailbox, in my driveway. FJ is parked about 40ft from it.
Took less than 1/2 hour to do both. No wiring mods. Unplug old light, plug new one in.
Guarantee you I don't work for Sylvania!! I build fire/rescue boats like the one in my avatar.
Bretty: - Where you at?
$ for my rig... I've added a few things (including lights) got some rustprofing today, yadda yadda yadda, gave the gov't a whack of my hard earned cash. I'm up to about the $7500CDN mark now. Still got more budget to go!
Does anyone know if those headlights put more load on the wiring? It might be a good idea to add one of the relay driven harnesses at the same time as a headlight swap, just to save some load on the headlight switch. Also to get a full 12v to those headlights. BTW I just put the Silver Stars and wiring harnedd in my DD Dodge Ram, with very similar results. As for the Fj40 I have IPF lenses, H4 bulbs, and the harness. Those suckers are bright, but it is a $$$ option
I must agree that the Silverstars are a huge improvement over regular halogens. I put a set in the family civic and it was a night and day difference. I find the difference to be very worth the extra money.
When one of the current headlights go in the 40 Silverstars are going in.
I don't know the comparative bulb specs but it's a safe assumption that bigger wires and/or a relayed direct battery feed for any headlight is a good thing to do. This has to be particularly true when the vehicle involved is a 30 to 40 year old utility truck given inadequate wire in the first place.
my headlights look like candle light. light doesn't hit the ground at all. i don't know if it's the old lights or if i'm not creating enough juice. it's a new alternator though, so i don't know.
Silverstars suck a$$. Sure they're brighter, but did you read the fine print? The box says the average Silverstar lasts 12 months. The ones in my Acura lasted 3 months. :mad: I had a 45 minute commute in the dark, so I guess that contributed to them burning out so fast.
I noticed in the specs that they are only rated for 150 hours (low beam, I think, and 50 hours high). 150 hours isn't much, even at just 2 hours per day. I don't know what a standard sealed beam is rated for, but it is certainly more than 150 hours. At $20 a pop, you could spend some pretty good coin on these lights over the course of a year.
Well, lets see here...... not flames - just thoughts!~~
Green73 - The stock lights (according to manual) are 50/40W (hi/low beam) The silver stars are 65/55 so you are 15W over your original bulbs on high or low. 15W @12V is a difference of 1.25A per headlight. Not a huge amount, but when you concider that you were originally only drawing about 4 amps per side, you are now up to 5.25 (roughly). Honestly 5 amps (high beam) is not a ton, but as Honk stated , it aint gonna hurt to put a realy in.
milesstarkey - try cleaning the connections on the back of your bulbs, pop them off wire brush them by hand, check how corroded the connectors are. Put some electrical contact grease on them before you put them back together. Your alternator could be fine, your battery fine, but if you have a bad connection at the bulb you will loose voltage and get a dimmer light.
Trevor - sorry to hear that yours blew, did you ever think that it might have been a fluke, or related to something else? Pretty quick to blame the manufacturer. I have a set of sliverstars in our Subaru Impreza, and they are great, havn't had any problems in over a year, with lots of night driving. - secondly, I have to disagree, silverstars don't suck, the stock lights suck. I ask you this...
What good is a light that lasts forever if you can't see anything with it?
Nothing on the box stating average burn life.... - but even if they only last me a year, I couldn't drive a year with the lights I had, I'd go insane!!
andrewfarmer - no they don't have a spot for parking light, they are pretty much identical in appearance to the ones I took out. - there may be another model that does though, the guy at the store said that it was a pretty standard model of light, so perhaps there was something else that has a light with the winow....?
spotcruiser - not trying to defend them or anything here but... @$20 a pop.... how about the kid I don't see - or the deer I don't see, how about the fact that with the stock lights, anything over about 40km/hr is overdriving your headlights and dangerous!! Not saying there aren't other options, I will be adding more lights once I build my roof rack - but hey, for the price and ease of the install this was a great budget option for me for now. - If they burn out in a week, perhaps I'll change my opinion !!
Please dont flame me for this!!
I installed Hella lights and love both the wide pattern and the brightness.
I would add that anyone wishing to make this change also install a relay system. Even if the current draw were the same as OEM the relay will do much to extend the life of your switch.
Also, when doing my swap I found the plugs at the bulb were is less than great condition. Burned, cracked, and abused from heat (poor connections). The replacement I used was from an old Datsun Z car. The reason for mentioning this is because the Z car plugs had a much thicker guage wire in case you wish to use more powerful bulbs.
